Camping regs
no and no..
the RCD will be provided by the campsite and your flex needs to be 2.5mm²
there are pre-made sets available that will be safer and probably cheaper..
something like this will do..
If the RCD is aready at the camp site why do they still do hook ups with RCDs?
So they can charge you more money?
In any case, having a second RCD will do no harm, and if anything is a good idea as it will provide some element of protection should the RCD on the site's part of the installation be faulty.
so i could do that but use 2.5mm cable and not 1.5mm.
Well from what i saw they used contractum RCDs and MCBs
I contacted the seller about the RCD unit he said £15 for the unit and no RCD so i was going to fit a nice Hager or Merlin-gerin RCD and a 16A MCB.
Jake
Right this is what i want.
a 240V 16A unit i can use to go camping with. The items that are at the first post are the items i was going to use and as asking weather i can use them. The item on the 3rd post is what i'm trying to make just using a single 16A socket. make sense??
Jake
IMO you should always provide your own RCD protection for mobile hookups. While campsites in britan are supposed to provide RCD protection I strongly suspect some of the ****tier ones don't and according to posts i've seen on another forum RCDs that spend years sitting in outdoor enclosures are not very reliable.
Have to admit to being a bit confused - if a single 16A outlet is enough, what's wrong with a 16A plug-socket extension lead? On the other hand, if you want something that will give you one or more 13A sockets, that would make more sense...?
