not sure, have only recentley moved in to the property. the hot water cylinder is upstairs with the boiler dowstairs.
whats the difference between the systems ?
There should be a screw underneath holding this on - no wonder most of them are brokennot sure, have only recentley moved in to the property. the hot water cylinder is upstairs with the boiler dowstairs.
On the front of the boiler if you pull the bottom forward and down, you will see a little red flat switch to the right of the boiler t/stat it will either be next to pumped or gravity, another way to tell is there are 4 pipes coming off boiler, or do you have a Y shaped valve on the system maybe in the airing cupboard
On the front of the boiler if you pull the bottom forward and down, you will see a little red flat switch to the right of the boiler t/stat it will either be next to pumped or gravity, another way to tell is there are 4 pipes coming off boiler, or do you have a Y shaped valve on the system maybe in the airing cupboard![]()
