not sure, have only recentley moved in to the property. the hot water cylinder is upstairs with the boiler dowstairs.
whats the difference between the systems ?
On the front of the boiler
if you pull the bottom forward and down, you will see a little red flat switch to the right of the boiler t/stat it will either be next to pumped or gravity, another way to tell is there are 4 pipes coming off boiler, or do you have a Y shaped valve on the system maybe in the airing cupboard
