It's not going to be so simple but it's very acheivable. You're going to have to create more damage than you probably wished for though.
You've got a permanant line, a switched line and a neutral.
A FCU is double pole, meaning it can only isolate two poles, normally permanant line and neutral. Your switched line will still be live.
Have a look at the wiring diagram which came with the fan and you'll see that the 1A fuse is situated before the swiched line comes into play so that it's protecting both the permanant and switched lines.
Thankyou Garymo
You're right, the 1A fuse is shown before the the switched line.
Thankyou so much for your help. i have a good understanding now and will take it from here.
Thanks again
