Hi i recently bought a broag remeha avanta 35c bolier and have just had a plumber round for a quote to install ..
He has advised i get a bigger gas supply pipe of 28mm from the meter to the boiler cupboard which i currently have 22mm pipework... The meter is approximately 10m from from where the current boiler is situated... Obviously this is going to involve more labour and materials with ripping up the floor etc to make good the upgrade..
He says i neeed a bigger supply because the boiler is a 35kw and also because im running a gas hob with single gas oven too...
Can someone please confirm this to be true or is the 22mm pipework i already have adequate to do the job as i had another quote from a heating engineer and he did not mention the pipe upgrade needing to be done...
Thanks in advance Gavin
