I have just replaced the washer part of the ball cock valve with what sounds like the exact same one as you did - part of a kit from B+Q (called 'Ball valve 1/2 inch high pressure part 1') with parts that appear to be almost identical to the existing setup. I just changed the plastic washer bit (about 1 inch long cylinder of plastic with black washer in the end) since the old one was nearly dead and leaking quite badly (never any whistling though), but left the rest of the old ball cock alone.
The new washer/old valve seems to work perfectly but whistles loudly (it does sound like a kettle!) when the tank is nearly full ie valve almost closed. It closes properly once the tank is full and doesn't make any more noise.
The whistling is slightly annoying but I'm more worried it might mean an imminent failure!
Should I stop buying stuff from B+Q and get a replacement washer from a plumber's merchant? Or is the whistling just an annoyance rather than a shoddy part?
Thanks, Matt
Thanks, Matt
