Potterton Suprima 80L with Honeywell Smartfit programmer
1 Jun 2010
Surrey
:shock:
The above heating & hot water is not programmed to come on in the night BUT between 2am - 5am the valve opens, the boiler fires up then shuts down again and again. If you look at the programmer it registers nothing. The 2 slide bars for CH & HW when tuned OFF - do not stop the boiler firing up again and again.
Only shutting off the electricity to the system.
Can anyone help? PLEASE?
2pm - 5pm is afternoon and not the night!
Is the boiler fitted in an outhouse or garage?
Well those times are in the afternoon!
You must mean 2am - 5am!
Its difficult for me to guess whats wrong. There could be all sorts of causes.
Perhaps water leaking onto an MV switch?
You will probably need a competent engineer.
Tony
The OP at first said pm but later edited her post.
You can see the edit details.
Tony
