Quick one,
can anyone tell me whether the current wiring configuration in my house meets regs?
Effectively, we have extensive solid oak flooring which has been professionally laid. Post flooring installation, it appears as if the leccy has installed some power sockets using the 1st floor socket supply.
Now, I cant see too many problems with this, other than it means the labelling on the CU mcbs is completely wrong. Which, if someone was having a slow day, could mean they think they have isolated the downstairs power when in fact the sockets are live.
I am intending to sort this out in the near future but for now can anyone simply say whether this is clearly against regs?
Other minor issue we have, the annexe attached to the house has a power supply connected to the Main fuse box. The cable has its own MCB protection, rated at 100A, fair one. HOWEVER, rather than istall a seperate RCD on the annexe CU, the leccy has installed the 100A MCB on the 20ma RCD side of the Main CU box.
Again, I will be sorting this, it works, but does it meet current regs? Only downside I can see is that the cooker/light/eleccy gates/garage mcbs are connected to the 20ma RCD protecting the house.
One thing I dont understand, we have some bare wiring in the garden (garden lights, disconnected using bolt croppers and having own supply at the annexe CU). When switched on at the annexe CU, this is tripping the "Garden Light" MCB and not the 20ma RCD. Why is the 20 ma RCD not tripping instead?
Diagram below:
Main supply ---- Main CU ---- 20ma RCD --------- Annexe CU (No 20ma protection)---Garden light MCB -------- garden cable
Thanks all in advance.
Diagram below:
