Can anybody advise me on insulation between the roof rafters?
My son has just bought a small house and I took a look in the loft at the weekend and noticed that it looks a mess. There is too much insulating material piled up between the joists and there is no felting under the roof tiles.
The excessive insulation has caused some condensation and mould to appear in one part of the ceiling, where the roof is closest to the ceiling.
I plan to get rid of some of the fibre, sort out the unbelievably bad wiring (if I survive being up there amongst it for long enough), then I would like to get some insulation between the rafters.
Is the spray stuff good, or should I just be packing in some rolls of insulation between the rafters? If you recommend the spray-on stuff, can I do it myself or should I use professionals? Can't believe that would be a cheap option.
If you recommend just packing the rafters out with insulating material, what should I use?
I have tried looking at a few web sites on this subject and they all want to waffle on and explain the science behind it. I, on the other hand, just want to know what to do.
Any suggestions much appreciated.
Thanks.
Paul
Thanks.
Paul
