    Dismiss Notice
Foil Tape on Between Rafter Kingspan Insulation
Discussion in 'Roofing and Guttering' started by camel307, 21 Oct 2013.
  1. camel307
    camel307
    17 Jan 2010
    115
    Thanks Received:
    2
    Bedfordshire
    Country:
    I have a lean to roof that runs away from the house at a pitch of circa 30 degrees.
    I have installed 100mm Kingspan between the rafters using a friction fit. I need to install 35mm Kingspan under the rafters, an 'under drawer'. I intend to fully tape every single joint on this under drawer to ensure a Vapour control Layer.
    Would anyone recommend taping up the gaps in between rafter insulation if i am fulling taping the under drawer insulation? There are minimal gaps with the between rafter insulation.
  2. freddiemercurystwin
    freddiemercurystwin
    21 Jan 2007
    19,873
    Thanks Received:
    2,218
    Devon
    Country:
    Just tape under the layer beneath the rafters.
  3. Sponsored Links
  4. noseall
    noseall
    2 Feb 2006
    43,480
    Thanks Received:
    2,685
    Staffordshire
    Country:
    We tape both layers. Belt 'n' braces and all that.
    Very sticky stuff that foil tape, no good if you have boxing glove hands! :mrgreen:
  5. catlad
    catlad
    29 Jul 2011
    4,912
    Thanks Received:
    744
    Lancashire
    Country:
    Yes tape it to make sure it does not move when the different seasons come ie. expansion and contraction.
  6. DIYnot Local
    3 Sep 2019
    Country:
  7. Sponsored Links
Loading...
Share This Page
