Trolley jack wont lower
31 Jul 2010
I have just bought a new trolley jack and when i tried it out it goes up no problem but i am unable to lower it.What i am thinking is that i am glad i did not use it to jack my car up without assembling it and trying it out in the house.
It is a Streetwise 2 Tonne hydraulic trolley jack,i would be grateful for any help with this problem.
Hi jonny,thanks for your reply,i have got it sorted now but i appreciate your help.
There is so much innuendo...I posted 3 times, and deleted, at risk of offense. No offense OP, but really? You tried a 2 tonne jack in your house, and it wouldn't retract? Because there was no weight on it to enable it to retract? I'm still amazed.
Really? Did you just say that? Are you living in the Big Brother house?
Sorry, you pumped up a 2 tonne trolley jack, and it DIDN'T retract, because no weight was upon it? Have I got that bit right?
Gravity doesn't weigh over two tonnes, otherwise the jack would be useless. You would be pumping the jack for years, so when would the gravity of the Earth take over to defeat your jack?
I think this has got to be the most stupid post that I've ever seen in any forum in my life.
But good on ya GillGill for posting it! Don't take offense!
It wasn't the best of posts but then you came along Mickymoody and posted more of your utter drivel yet again letting yourself down.
Mickymoody,
are you infact saying a trolley jack with NO weight on it will NOT retract? if so you are WRONG mate
Mickymoody,
A trolley jack that retracts with weight on it is called murder. A trolley jack that retracts with no weight on it it called faulty. It will EVENTUALLY decompress, but not without manual help, unless it is broken.
Unless you know better and own a "Streetwise 2 tonne hydralic trolley jack", and know better?
Mickymoody,
i dont know better mate, but i have 2 trolley jacks a 3 tonne and a 2 tonne and both are less than 12 month old, BOTH will retract when at full height and the handle turned, 3 tonne jack is a sealey, 2 tonne jack is a draper, surely both of them cannot be faulty with the same fault?
Mickymoody, you're talking drivel. Any trolley jack will lower under it's own weight if the release valve is opened fully.
By example - the OP's post suggested the alternative. Therefore justifying my comments, and means you talk drivel. The OP's trolleyjack doesn't retract under it's own weight, so retract that statement, and apologise. Do people read a thread thesedays?
