Zanussi ZWI 2125
26 Aug 2010
Lancashire
Help!
My washing machine is retaining the water after the wash cycle, it stays filled with water on completetion.
The machine is just over a yaer old...
I've emptied the water and tried over three times..still no joy
I've checked the pump filter...seems okay.
The thing is, there arn't any error codes popping up on the display either
its quite an expensive model with gr8 reviews...
where has it all gone wrong!
Does the pump make a noise have u check the waste pipe end does. It go into the sink spigot that could be blocked
Checked wastepipe... it seems to be clear... not blocked
The pump does't seem to make any kind of noise at all...
water goes in ...but not out.
hmmm
Check the pump with a continuity tester poss open circuit or a small item jammed in the impellor.
would i need to open up the machine to check the impeller or to check for an open circuit?
or is there an easier way for this.
starting to sound very technical.. but im gonna have a go ..how do i go about doing either of these.
Pump is at the front just tip mc back and the pump is on the back of the filter held on by 3 screws,then just a connection on the back that's what you check put a tester on the 2 pins on the pump.
everything seems so spanking new...
what reading am i looking for here!
impellor looks clear
Check u have 240v to the pump plug a meter on the end of pump wires.
