After much scratching of head and reviewing these forums I've come to the conclusion that the diverter valve on my Ferroli HE31C is at fault. All the usual symptoms including good DHW but no CHW with error code D2 when trying to call for heat.
A swift tap of the diverter valve with a good screwdriver has 'fixed' the problem so I presume the valve is sticking, so, to my question(s).
1. Do I need to replace the whole unit or is it just the 'front bit' (as has been suggested on other forum posts), which is held on with 2 painted screws (leave well alone) and 2 non painted screws that seem to attach it to the bigger (and more complicated) body. ??
2. If it is just a case of removing and replacing the front bit, do I have to drain the system down first or is there a seal behind preventing water loss.
3. And finally, where can I get one of these thingies ??
Here's hoping !!
Chap
Here's hoping !!
Chap
