beat me too it again lol
hi
1 no, pump is in loft with boiler, yes a littleIs the pump in the airing cupboard? When you turn Ch on, does the pipework at the pump get hot, before and then as far as you can feel after it?
Is the spindle in the middle of the pump spinning?
You should have water at the spindle.(pump vent)
Is the towel rail the highest point on the system? Or is there another floor?
Does the small tank run if you vent say half bucket water through an air vent or drain off cock?
Is the 3 port or 2 purt valve opening\
As said either airlock, cold feed blocked or pump knackered.
pump is in the loftWhere is the pump:"
Put a screwdriver in the pump vent hole, is it spinning?
Is the small header higher than the boiler/pump?
There isnt a big red vessel up there is there or pressure guage?
What is the model of your boiler?
Can you take a pic?
Valves are in the post above mate
Can you take a pic?
just to check
when you bled the towel rail, water came out. But the pump is higher than that, and appears to be dry?
is there anything else as high as the pump, and is it also dry?
how far above the pump is the "header tank"
if you tie up the ball valve in the header tank, and drain a pint of water out downstairs, does the water level in the header drop by one pint?
turn the system off, above the pump to the left is a 15mm pipe, can you crack open the 15mm brass coupling and see if you get any water from it/?
May be worth while placing a few towels and a bucket under neath.,
