I moved in a building and inherited the shower from the previous owner. Unfortunately I don't know the model apart from it's Triton.
The shower uses hot water from the boiler and cold from a tank in the loft.
Everything's fine until a day it won't stop (Both water flow and power) . I could still adjust the temperature and water flow but couldn't stop water running through the head even the control is on the off position.
I had to turn off the switch from the side and decided to open the front face to have a look (a bad choice) ... Without any joy after half an hour's inspection, I Put the face back in place. The power's not even on!! (it's a manual one with no indicating lights so the only way to tell whether it's on and off is from the noise) Not it just sits there quietly
I contacted local parts supplier for a solenoid as this seems like the main fault according to other people's suggestions, but they can't tell me which to buy because I'm not sure about the model.
Any Suggestions will be very much appreciated..
