worcseter bosch greenstar he plus problem
A
angelf
Hi moved a worcseter bosch greenstar 30 & put a new flue on it. Now the boiler will fire on hot water mode, make a loud noise & go of.No heating either. No mfg instructions available by customer! is commissioning it any different to comissioning other WB combis he plus boilers? Any ideas how to solve issue please?
DO you know what you are doing?
Should you be moving boilers at all?
Why not post in the cc?
boiler is shutting down for reasons of,
the answer is in the letters below.
YTEFAS
or
KCOLLIP
yes multi choice answers just like sag assestments.
razor,thats a great answer.
if ita a sealed system boiler and air under pressure is used to feed gas to the burner,there is a very good chance it will work.
execpt for the condense drain, i need to think how to drain away the condense.
condense trap needs to be rotated.
sorted,a condense pump set to run all the time will clear the condense.
ok untill it fails probaly rather quick.
Why did you put a flue on it?
Why did you move it?
Why didnt you just leave it alone?
Why?
He may have been asked to move it.
But as someone who is not Gas Safe Registered he should not have been working on it.
No one here should be giving him any help with his illegal working. The only advice is to call a registered professional to check and correct his errors. Hopefully to report him for illegal work too!
not to worry-am gs reg & have posted it in cc......and got the problem sorted. ta
