Cast Iron Guttering
30 Dec 2009
Lancashire
I have a problem with my house guttering leaking at various joints. Anyone recommend some type of paint/sealer that can be applied that will solve the problem without having to remove and re-do the joints. I did slap on some car underseal paint, but it didn't last long.
Regards,
cansado15
I have a problem with my house guttering leaking at various joints. Anyone recommend some type of paint/sealer that can be applied that will solve the problem .
There is no paint/sealer which will last any length of time!
cut the bolts off, clean out the old putty, reputty and fit new bolts.
Then they wont leak.
If they are leaking then the best thing to do is, remove it all and replace with plastic.
You will spend more time trying to bodge it up than doing it properly.
Andy
Thanks Guys, I will go with a temp repair and refurbish with putty etc next summer, then the problems solved for years.
Regards,
cansado15
You can get lead type putty that you use with stained glass window making.
