Advice needed please
11 Nov 2010
Staffordshire
hi all i need some advice concerning an extension wall we have lived in the house for 16yrs and the previous owners had a single storey extension built 18yrs ago over the past cople of years i have noticed a crack where the extension wall meets the back of the house so i decided to strip the plaster back to have a look and it looks as though the wall isnt tied into existing brickwork and there is a 15mm gap all the way down any advice please about what i should do thanks
It is more than likely tied with a steel starter clip and the 15mm gap is common
This joint will crack and the extension will always move slightly compared to the main house
Fill the wall joint with some polysulphide mastic, then plaster it back up and run some flexible caulk up the corner
anything to worry about woody because it is an interior wall and a exterior wall why is the 15mm gap common and if i fill it with mastic will it crack again and what mastic should i fill it with thanks
Its common because 10-15mm is the thickness of many wall starter ties or even just a brick joint
The joint is filled with mastic so that when movement occurs, the joint flexes and does not crack
Just to let you know problem sorted Turned out the wall was only tied in in three places with homemade brackets so i took part of the wall down and fitted a wall starter tie in and blocked back up jobs a good one now thanks for your advice
