Hi All.
Trying to keep brief; occasionally asked to do bits of plumbing work - though not my speciality - but has to sometimes be done
Hot water gate valves seem to be my curse - either being seized open, won't shut off fully or the spindle seems stripped - spins with no resistance and does nothing!
Noticed Travis Perkins do a "bung" arrangement to block off the feed inside the storage tank. Are these worth getting?
Does anyone consider using only the "bungs" and never touching the gate valves. I live\work in Berks - assume all down to hard water?
Can you replace just the internals of the gate valves - unscrew the centres and swap out? Is there any sort of "standard" to allow this? Have even come across TWO gate valves in series before - about 6inches apart - both knackered and had to empty the sotrage tank!
Also, seized open mains valves off blue poly pipe - how much "force" can you use to try to close? Any risk of twisting the valve off the poly pipe?!
Cheers for any advice,
Neil
Neil
