Hi folks I'm looking for some help and advice and this seemed to be the place to ask it.
I have a Biasi M90e 24S boiler that is 7 years old. It has been working fine until the last couple of months.
I'm not trying to 'do' anything with it myself, I'm an electrical engineer not a gas engineer, but I am on a Homecare contract with British gas, and after 5 visits they still haven't fixed my problem so I'm asking for pointers to give to the next bloke who turns up.
The problem is that at least a couple of times a day the boiler is operating normally, then when it tries to fire up as it does to maintain temperature when its on, it starts whirring, but no flame comes on, and after 10-15 seconds it drops onto lock out. If I reset it immediately it will do the same thing indefinitely, if I wait 20 mins It will come on again and either stay on, or come on with the timer until the next time it locks out.
I haven't really noticed any correlations between times of day and when it does it, other than it is slightly more frequent first thing in the morning when it is coming on with the timer, and it has been happening more in the past few days when it has been really cold.
The guys who have come so far, have replaced 2 temperature sensors, and dropped the operating capacity twice, once to 22k then to 19k. This hasn't fixed the problem, and to be honest has made it quite hard to warm the house up.
Also the second guy said my pressure at the meter was fine 20mbar but at the boiler it was low, so I should get a replacement 22mm pipe put in. Duely done that and it hasn't solved the problem either.
Since they were worried about the temperature and had replaced sensors and turned the boiler down I have been paying attention to that and on the gauge on the front it gets to a maximum of 60 degrees, but it can cut out at any temperature. Even from cold.
The only other thing I have noticed is that after the guys had come out and done their stuff, it worked for about a day and a half each time, before going back to locking out 2-3 times a day. (5-6 today)
Ok, so any advice gratefully received. I think I have covered everything I have noticed but if you need more information and its safe for me to get it please ask.
Hoping not to have to use more than one more day of annual leave staying in waiting for British gas, as I'm running out!
