Hi There,
I have condensation in my loft in the form of beads of water on the underside of the bitumen roofing felt.
I have a combi boiler located in the upsatirs airing cupboard which has a vertical flue which goes up through the loft space and vents out of the roof.
I have noticed that when the heating is on and I have been up in the loft I can feel warmth against my face when near the flue pipe.
The flue looks to be in good condition and is the type that 'push fits' together. I have put my carbon monoxide alarm up there to see if the flue is leaking and the alarm doesn't sound. Before anyone asks, yes the alarm is working!
My question is, could just the heat radiated from the metal flue be sufficient to be the cause of the condensation problem. The loft feels cold and there are cobwebs blowing around so looks to be sufficient ventilation. There is also the required depth of insulation laid between the joists and across the rafters.
Has anyone heard of lagging the flue pipe? I assume that special high temperature and fire retardent material would need to be used?
If anyone can advise on this then it would be most appreciated.
Thanks.
Thanks.
