I've had the above boiler 10 years fine but now giving me real trouble. I have searched everywhere for similar problems (but similar is not the same) and have followed advice i've found.
CH runs for expected time and switches off for a while, then fan (not burner) turns on and safety lockout lights and fan keeps running 'forever'. If i switch off at the mains for about 30 minutes and switch back on then fine, but same problem occurs. If I don't wait that long then powering up just gives me the lockout and fan (with ch and hw off). HW on it's own does not appear to cause the problem, but I don't run HW for very long, however if heating has been on and then I use hw the lockout occurs shortly. The overheat sensor (pushbutton underneath) does not trip. Pressure stays between 1 and 1.4 Bar.
All radiators get hot fast when functioning - I do think they are a bit hot even though the heating 'dial' is set to minimum.
I have so far had two (one halstead suggested) engineers who have not been able to fix the problem. The Halstead Tech line (now Dimplex I think) can't help over the phone and have given me another engineer to call.
So far this is what has been done;
Cleaned Venturi and fan (all very clean anyhow). Fan works fine.
Replaced Flow diverter assembly (there was a sticking switch actuator) The original was also really clean inside and I could have fixed the original it turns out - shame.
Removed heat exhanger - and was clear of sludge (I use CH protector)
Replaced thermisters on the diverter assembly.
Replaced PCB (shame - same problem).
Checked pump function.
Checked for air and bled everything.
Checked solenoid function on gas flow modulator and gas pressure.
Checked wiring continuity where possible.
Checked flue for obtructions - clear.
If I run CH for five minutes every 15 minutes everything is fine but I can't do that forever.
Both engineers have given up. This has cost £350 already and have gotten nowhere. If anyone has any suggestions as to what to look for next that would be great. This is driving me nuts, as I can't think of anything else to do/get done to fix this
Any help much appreciated. Thanks in advance. Dave.
