Please can anyone help on this cold Xmas Eve!
I Live in a flat, We have 4 radiators, a potterton Kingfisher boiler and a header tank (At ceiling height) above a primatic cylinder.
Yesterday the actuator Valve that I believe feeds the DHW into the primatic cylinder failed (Lots of clicking and no actuation). I replaced this with a Drayton 2 port actuator valve from B&Q. Fitted it ok after shutting all the hot water services pipes off. When I removed the old one, about 1/2 a bucket of brown water came out.
Once the water had stopped I fitted the new valve and then I turned it all back on.
The valve worked when turned on but the water does not heat up. I Have good central heating but no hot water.
Have I done something wrong or was the lack of hot water before i started this amateur plumbing attempt pointing to another problem?
I tried running all the hot taps to try and sort any possible air bubbles out following the loss of water from when i removed the old valve but no joy.
Please can someone help. I have no hot water for Xmas!
Picture shows the valve i changed.
Merry Christmas!
Merry Christmas!
