Actuator Valves
28 Jan 2008
Having problems with my hot water - it won't switch off and is constantly asking the boiler to fire up. Water is VVVV hot. Have changed the programmer on the boiler - to no avail so think actuator valve is not working - seems to be sticking as i can move it manually. I have drayton valves in the airing cupboard. Can I easily change or stripdown the valve for the hot water. Are they expensive to buy or difficult to fit a new one??
Stat is cylinder thermostat in this case. The temperature control on the cylinder
Thermostat appears to be working. Valve appears to switch on hw when on timer, but will not switch off again (unless i move it manually). Does this mean it needs replacing. Have read that these valves can be easily switched - or does the plumbing need to be messed with.?
