Hi (and a Happy New Year)
Just joined the forum.
After reading lots and lots on the forum trying to tie down a fault on the above boiler, I have tried the following.
History:
New house with above about 8 years ago.
I don't know a technical term, but the system has 1 tank for both CH and HW
New PCB installed by BG about 1 1/2 years ago, from a maintenance contract.
Called BG out 3 times since then as boiler shut down prematurely and try to restart several times but failing, or wouldn't start (continuous green every second or so), or try to start fires up but shut down immediately.
Anyway BG,on each occasion changed the overheat sensor and seemed to fix problem for a while.
Cancelled BG contract as it seems they can't fix the problem. Last thing they did on request was to leave with a new sensor fitted.
OK, so the problem has returned. Same symptoms as above. I can switch off/on for a while until it stays fired up for a while, but unless I stand over it, the CH starts to run cool/cold and HW same. Usually find boiler green light flashing every second or so, or trying to restart and failing with green light flashing every second. No red light seen at all - ever.
From the info gleaned here, I have tried a simple test. I removed the cover, removed the overheat sensor (still connected electrically) and let it cool down and let it hang free. Restarted system (still with cover off) and everything works a dream.
So, unless I am missing something, simply replacing the sensor (again!) should get the system back up and usable,
However, why should my system eat through these sensors? (BG say they rarely had to change them)
I know about the safety infringements, but at the moment, until I can get the issue fixed I will need to run without the cover/sensor (under supervision of course)
I have tried finding a source for the sensor (it is just a small plastic cap with a tiny blob at the end of the 2 wires poked into a hole in the pipe fitting(loosely).
Would anyone here be able to point to a source, or part number or any other help info appreciated.
The cost must be minimal as the part looks so tiny and flimsy - can't be much in the making of them.
History:
