Good morning all,
I have a sime ecomfort 30he condenser.
The fibre washers started to leak on the aquagard filter yesterday, so I changed them with apparent success. I then refilled the system with some cleaner in and ran it for about an hour, whilst keeping a close eye on the filter for leaks. There was a very small drip, which was remedied by a further tighten of nut.
Confident of my handiwork, I then drained the system down and added inhibitor and a 'leak stop' to be on the safe side. (all chems b&q's own brand).
I ran the system for a good two hours after bleeding rads, everything appeared normal pressure-wise. With the usual topping up after bleeding rads etc.
I then went to bed. Got up this morning, and it'd lost about a bar of pressure, which was a bit concerning. After a bit of searching the interwebs, it looks like it could be the expansion vessel dumping water out of the PRV maybe?
My question is how to repressurise the vessel (if your learned opinions confirms this is what the issue is) without draining the system down again, as I dont want to lose the £30 of chemicals i put in!
Many thanks in advance,
Matt
Matt
