changing my lighting
13 Feb 2010
Nottinghamshire
can i change my existing light in the kitchen for 5 or 6 50w down lighters all wired from a hd jbox ie 1 cable for each fitting.would this have to be part p approved or is it non notifiable.thanks in anticipation.
Yes though you would be mad to do so- 300watts for 60watts doesn't make economic sense.
very big jb needed and jb must be accessible.
Yes
No
in your opinion what would be a better option,must be dimmable.
Not sure why you need a dimmer in the kitchen - it is a work place! While downlights can be dimmed - they tend to just put spots of light on the floor rather than lighting the kitchen as a whole. You would end up putting undercupboard lighting in as well to give you the light you need.
By the way if you just replace your current light unit, which I assume is a central pendant light or fluorescent tube, with a similar single unit then it is not notifiable.
I would suggest that you search the web using the search term IP 44 rated lighting or something similar. There are lots of designs out there.
If you really must have spot lights, get a single fitting with four or five spots mounted, then it's a non-notifiable replacement. But spots ain't a good idea for kitchens.
PJ
Fluorescent lights can be dimmed - either get ones with dimmable ballasts, or ones where the ballasts can be easily replaced and swap them for dimmable ones.
