Shower - hot and cold
19 Nov 2006
Birmingham
Hallo all.
I had a simple message from a mate which can be summarised: "shower running hot and cold".
Pressure is not the issue. I do not have any technical information, but can you just advise if there is a 'usual' fault resulting in these symptoms. I am guessing that the power to the shower cuts out, without the water reaching the normal thermal cut-out temperature, meaning that cold water is produced for a few seconds. Problem is intermittent.
thanks.
Thermostat. Are you sure about the pressure? That's the top two of my list.
PJ
