Need to replace my 7 year old Bosch single oven (2.85kw). At the moment its connected via a 13amp conventional socket behind the cooker (under the worktop). This is wired up to the kitchen circuit that the hob is on (if I turn the cooker master off it turns the hob and oven off).
My query which I hope somebody can answer is if I decide to go for an oven with a higher load that requires 16 or 20 amps is it a simple case of getting somebody to hardwire the cooker into the current outlet (ie replace the 3 pin socket) or will more work need to be done. Thanks.
