What are the pros & cons of S plan as against Y plan
y plan up to about 24kw any more then its an s plan, has the valve always made this noise? it would be cheaper to change the 3 port valve head than put in an s plan (if it the head thats causing the problem).
... which is a real pity because an S Plan prevents pump overrun. Why fit two valves when one does a better job?
you need two valves regardless on an unvented so S plan for me... which is a real pity because an S Plan prevents pump overrun. Why fit two valves when one does a better job?
