Disc Cutting Blocks/Bricks
6 Mar 2011
Cornwall
Part of my low block built garden wall has come down and I want to hire a disc cutter to cut off the uneven blocks to tidy it up.
The wall is 10cm thick x 30cm high. What size cutter should I hire?
Would a 9" be big enough or is the rad of the disc too small?
Thanks for any tips.
9 inch is fine, but then you have to do it from both sides as the 9 inch as a cutting depth of 2 to 3 inch
It would be cheaper/safer and make more sense to re-build a single course block wall with bricks at the desired height.
Thanks for the info fellas.
The wall runs around the border of the garden aprox 15mtr in length and it is the open" end that has disintegrated over the years, most of it before we moved in otherwise i agree it may be better to rebuild it.
 8)
