The other day a council pest controller said he was unable to go into my loft because it's not boarded. Aware that other trades (TV aerial, electrical, plumbing) might take the same view in the future, I'd like to put down at least a longitudinal walkway so that access can be easily gained to the far end.
But our loft has had top-up insulation, in accordance with "official" guidelines, which means that the joists all have a thick layer of insulation matting on top of them. So what is the proper way to lay a strip of boarding, please?
Do I cut a 2ft-wide (or whatever) strip out of the top layer of insulation so that I can simply screw the boarding straight onto the joinsts, and then lay the cut out insulation strips back loosely. Or do I put timber blocks onto the joists to raise the boards so they pass over all the insulation?
