Currently I have 4"x2" joists with 18" centres, and filled with 4" of insulation. There are two brick walls directly underneath the loft that the loft floor rests on. Longest unsupported span is 3m.
I wish to board the loft for light storage only but add some extra insulation.
Plan: Lay 50mm insulation boards at 90 degrees to the joists. Where there are cables crossing joists, scallop out the underside of the insulation boards to leave a gap so as not to crush the cable.
Lay and screw loft boards over the insulation boards (and mark where there are cables).
Should use foil backed boards or just plain?
Is this ok? I know the recommendation is 270mm of insulation, but that would impact on my space, as the roof is fairly shallow.
Thanks for any advice.
