Looking for help and am really getting desperate now.
I have had a problem with my heating system for a few years not and it is gradually getting worse. The top of radiators are hot and the bottom is cold resulting in the rooms not being adequately heating in the cold months.
Boiler, rads and all pipework is 6yrs old. Boiler is a Vokera Linea Max with 22m pipework throughout. I’ve had the inhibitor in it since new.
Recently I have treated several times with X400 and flushed but it’s made no difference. I replaced all downstairs return pipework and installed a new radiator in the living room. It immediately got the same problem. I have had folk in to power flush the system and they said no blockages or restrictions in flow or significant particles found.
I have had the manufacturer from the boiler out and they sat the boiler is working fine problem is a blockage in the pipes.
The burner comes on and heats the water until it reaches cut-off when the flow temp reaches 82degrees. The burner then stays off for three mins. Temp gauge is then down at around 43 degrees. I therefore assume this is the return temperature.( the boiler temp gauge is on the flow pipe) When the boiler comes on the temp ramps up to 82 where it cuts off again. This repeats constantly and because the boiler does not stay on for long each time (1-3mins) the system and rooms do not heat properly. Even with the boiler at max the return temp only gets to 43. I have changed the pump for a Grundfos UPS15-60 (recommended replacement by Vokera) and this made no difference.
I have fitted a flow meter and now know that the flow around the system is 500l/h. There is a radiator about 1m from the boiler and the flow rate does not change if this rad is open or closed.
Help can someone give me an indication of where they think the problem lies and what I should do next.
Thanks.
Thanks.
