Hi Guys,
I'm on the last few days of my bathroom project.
Yesterday I removed a cheap tatty radiator from the bathroom and want to replace it with a towel rail type.
The existing rad pipes come up through the floorbords at 730 ctrs, the new rad will have 550 ctrs.
I have located the pipe under the floor I wish to move to create the desired ctrs.
Several questions;
Can I just cut the pipe to accept a new T-connector and then blank of the old pipe just below the floor with a speedfit stopper, or do I need to remove the T on the old pipe and added a standard connector?
The radiator is one of two in the loft space, so can I simply turn off the combi boiler, and turn off the valves of the second radiator before cutting removing the old valves from radiator 1. (will be towell warmer rad)
This would then only need me to drain the water from the pipe on in the loft, so I can do this with a frying pan... is this correct?
I then plan to add the new towell rad with new valves, open up the air valve at the top and the filling loop under the boiler.
And yes, then add some inhibitor to the radiator wia the air valve.
I would like to do this tom, so any advice would be very much appreciated.
Thanks Franc
Several questions;
Thanks Franc
