It might be a few appliances with mains input filters ( capacitors to ground ) and the transient voltages on phase and a bouncing neutral as the network phases and neutral settle down after reconnection.
But not test failure modes or validate fixes on the installation you'll be using?1) Want to be able to repeat the failure ensure it's fixed.
You're going to remove live tails from the VOELCB, and then insert live tails into the switchfuse?fold the tails double and secure with a cable tie. That should keep the electrons in.
2) fold the tails double and secure with a cable tie. That should keep the electrons in.
* On a TT supply the earth fault loop impedance is very high.Ricicle, why shouldn't I use a metal clad with appropiate bonding ?
