The hot water pressure coming from the boiler is very weak. The water pressure going into the boiler is very strong. I am constantly without hot water. Can someone help?
Pressure and flow are two different things. If you hold your thumb over the spout and nothing builds up, it's lack of pressure.
If it does build up but little volume, it's a flow problem.
