Hotpoint wash machine wt761
13 May 2011
Humberside
Hi all, I've got a problem with the above machine. Set the programme, switch on and the discharge pump and fill valves operate at the same time. (I have just replaced the fill valve solenoid 2nd hand) The display flashes f-03 which I have been told is the thermistor problem. What is this and where is it fitted. Anyone help?
Thermistor is on the heater but it also means a pcb fault
Thank you very much for the answer. I had thought the pcb might be affected when I read "short circuit" in the handbook, but I am hoping against hope.
