At the end of the day they are paving slabs, you'll only have problems if you do a half assed job of it. Bradstone supply most of the sheds and builders merchants so are probably the largest supplier in the UK.
bradstone stuff is very good quality but pretty expensive. Over the long term i.e 10 plus years the stuff can loose it colour slightly if washed a lot as it is only dyed concrete afterall.
i assume by that you don't agree?? I find it more expensive than most but i think they make well styled and good quality stuff. Of cousre for some people any concrete will always be bad but their wet cast stuff is visually better than most other mftrs.
