Evening all,
We are decorating our living / dining room and today i removed all the dado rail from the walls. It came off pretty easily not ripping any large chunks of the wall off (thankfully
Where it came away, it has pulled off the under layer of paint, leaving wriggly lines of exposed plaster where the dado was glued on.
Do i need to 'seal' the exposed plaster before re-painting the room
Firstly i will be sanding the dado section down, and filling any small chips with pollycell then re-sanding to a smooth finish.
If it does need sealing will it be a case of watered down pva glue
Thanks for any answers
