Hi all,
We have had fitted a 9kW electric boiler. The cable used from the double pole switch (fitted by an electrician with the RCOB) is 6mm - is 6mm suitable for this?
The cable is 25cm long and we run the boiler at under half demand.
It does not get hot just a slightly warm.
The electrician wants to come back and fit 10mm and a different termination box to accommodate it - costing £95 which is money we just don't have after the initial bill for the electrical work and and boiler install.
If we can safely avoid it we will.
Thanks,
Jack
Thanks,
Jack
