Self Cutting Tap - CH
Load of cr*p a the best of times.
how do you intend on fitting a rad using self cutting taps ?
I was going to fit the self cutting value & then use a tap to 15mm connection to run the pipework I need.
The only other method I was think of using was the pipe freezing kits but I only have approx. 6" of pipe tp play with?
Not from another rad no; there are two old radiator stalks that have been cut back close to the floor. The previous owners removed the rad to install a big american style fridge/freezer but I want to utilise the stalks to get a rad back. I want to run a short lenth of pipe to locate the rad approx 2 - 3 feet from where these stalks come up from the floor.
This would obviously involve draining the system though which is what I wanted to avoid if at all possible.
