Thanks for advice.
Pics are difficult just now because the area has been sheathed in plastic to reduce the dust spreading. So I can't get far enough away to get a proper picture.
1. why were the joists replaced?
there was dry rot from the flat above.
they replaced the rotted ends but not the lintel.
2. are the lintels fungus damage free?
no, the lintel is fungused which is why it is being replaced.
the room has been rot treated before and all examination indicate the rot was in the property above and localised to a relatively small area.
3. presumably we are talking about chamber joists here?
yes.
4. why is the ceiling being stripped back 2ft?
two reasons, to give full access to replace the lintel.
to ensure that all the rot has been removed.
5. what do you mean by "lath and plaster has been wall stripped"?
the wall below the lintel to each side of the window is old lath and plaster.
it was stripped to check if the rot had travelled further than the lintel and we decided just to strip the whole wall so that insulation could be added.
I measured the lintel accurately and it is 1600mm on the largest par of the gap. With a 200mm overlay. It is 250mm deep and 150mm high.
I am happy to use the easiest of a standard steel box lintel, or concrete, or a steel beam. I would like to get some advice on the structural strength to choose.
The weight should not matter too much for fitting, obviously lighter is easier. More importantly is size and manoeuvrability as this has to go in from below.
Read more:
//www.diynot.com/forums/viewtopic.php?p=2047350#2047350#ixzz1Rui3NImd
