Your local electrical wholesaler should be able to get that for you -
It will depend on the size of cable required - 4mm three core rarely in stock and works out about £4 metre. For size of 2.5mm three core some sheds sell them.
Look here for previous post which explains what each element of the code is:
The properties of the cable quoted by the manufacturers seems excessive for there purpose - ceramic hob. Being able to withstand 180c I can understand but for what purpose is the -55c minimum temperature needed? Do you live in a igloo
