I'm not sure that it would achieve what you might hope. I'm not at all sure that changing a whole circuit from 1.5mm² to 2.5mm² cable comes within the scope (or, particularly, spirit) of 'replacing damaged cable' - so (although it's obviously a move in the 'safe' direction) it's quite probably still theoretically notifiable.If that's the case John I will take the one peg off, it's now a radial circuit!
...and, before you get the wrong idea, I should point out that I'm not an electrician, so I have no axe to grind!
Kind Regards, John.
