Could someone work out this problem for me.I was asked to instal a Pvc armour cable to supply a new house which is 350 metres away from the electricty supply box.The cable will be in in a track dug down 2ft,then covered over with earth,it will be a single phase 240v supply, the load current with diversity factor will be at any time, not greater than 60amps(for about 1hr in the morning) and probably lower (20amps)most of the day.The isolating device at the electricty box will be an overcurrent cb,and in the house rccd,also i would sink spikes at either end of the cableand and bond the earth onto the armour.First of all what do you think of the isolating devices and what size of cable would you reccomend
