- Joined
- 19 Feb 2006
- Messages
- 31,895
- Reaction score
- 11,487
- Country
Agree with the point that for point of use hot water through something like a plate heat only that avoids stored water could be an issue, firstly common to all solutions is your current flow rate.
The other issue that was mentioned is that of the gas supply required to heat a stand alone plate, a standard domestic gas supply/meter would only do about 27lpm flow at a 35deg rise,again not ideal if your running multiple outlets.
Stored water is likely to be a must, that's now wether you opt for thermal store or unvented.
Current thermal store market is so expensive, the only one I would recommend is DPS, but since spec flue have taken over their prices have nearly tripled making them unrealistic.
Each to there,own, lots of solutions but some limiting factors with cost I presume being one of the greatest.
