New Thermostat
23 Sep 2006
Looking to replace my Honeywell dial stat with a digital readout stat, nothing fancy no wireless. just one to replace it on the wall. I have a Worcester Boch Greenstar 24i System boiler, any recommendations please.
Thanks dan_robinson will it be a case of a straight swap with the old one, are the wires the same don't want to start messing about with more wires.
Would it just be a straight swap wire for wire or would it be more technical.
Can the Honeywell dt90e just be used as a stat as I already have a timer for the boiler.
Yes.
Almost.
There is no standard for wiring heating controls. So, if you post which wire goes to which terminal of your old stat, we will give you the correct wiring for the new stat.
Thanks guys when I get my new stat I will post pictures of both wiring setups.
Cheers the noo
Willie
