Looking for some help in balancing the central heating system. I understand the basics of how to balance a system but I am a little baffled by some of the contradictory info out there! I have made some assumptions below, happy for anyone to correct me if I am getting this wrong!!
Boiler is a Worcester Bosch Greenstar 42CDi combi. It is new, less than 6 months old and yes it should have been set up properly by the Bosch W approved heating engineer, long story but as he is not answering the phone about the magnetic filter that he was supposed to fit I doubt he is going to entertain me about the system not being balanced properly. I know from watching him that his version of balancing was to twist a few of the valves before rushing out the door and that he didnt measure any temp drops, and from the fact that the last radiators in the loop are not heating up properly I started to look into the balancing myself.
I believe that the temperature drop across the system should be 20 degrees but most of the stuff I have read seems to refer to balancing radiators with a temperature drop of 11 deg. I think this is to do with older versus condensing boilers but from some of the posts here I have read I understand that the radiators may be designed for a 11 deg drop. They are older radiators mostly, about 20 in total.
This is part of what is confusing me, should I be setting the drop to 11 or 20 or something in between?
Also, I have already started to balance based on what I know and this has improved things, particularly with respects to the upstairs radiators heating up but I want to set this up properly and should I be going back to the start and checking the temperature drop across the system with all valves fully open. If this is not 20 deg does this mean the pump is not set correctly and is this something that I can adjust myself on this system (I think it is internal to the boiler)?
Sorry for the long post, appreciate any thoughts.
