The dishwasher will neither drain out nor start washing.
Every program starts by emptying the water from the machine. If there is water in the sump and I start a program, you can hear the click of a relay behind the top buttons but no motor sounds and the machine doesn't empty. After about a minute the program and drying lights flash. The manual says this indicates a blocked siphon but doesn't say what that is or how to unblock it.
If I bail out the sump and then start a program, it clicks, waits a few seconds, fills up, stops and then, after about a minute, the same lights flash.
If I lay the outlet hose flat across the floor it will drain and any water poured into the machine will pour out of the hose so there doesn't seem to be any blockage.
I've had a quick search of these forums and there's talk of pumps and impellors - what's the likely culprit and how do I find/access/check it?
Thanks.
Thanks.
